| | | Forums66 Topics128,096 Posts1,056,473 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | My Chasis and Engine are 3hours away. I found an exhaust manifold at a local flea market. Casting Number 3835587. Note said it was for a 250, but it looked like it was for a 235. Heat riser was loose. Studs on exhaust side were clean.
Is this the right manifold for my 58 Fleetside truck ?
What would a typical price be ?
Appreciate your assistance folks.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Don't know if it is the right mainfold for your 58 Fleetside truck.
But casting 3835587 is right for a 235.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | I picked up the manifold. Looks like an identical match. Came with intake and exhausts still bolted together. Hardly any rust on the exhaust.
The head flange surface has some rust. I guess I should get it re-surfaced.
Any suggestions if I should make the effort to separate the manifolds and replace the heat riser gasket, or should I just leave it together?
Not sure why, but my original set was installed without the intake alignment rings. Anyone got a spare set ?
