5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#65336 09/05/2006 12:19 PM
I have a 49 1/2 ton pickup truck. I am leaning toward putting a 292 with an automatic transmission, power steering, air conditioning, & power brakes. Were there any year cars or trucks that came with a 292 that would have all the brackets as "factory options"? Thanks in advance.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#65337 09/05/2006 2:56 PM
Quote
factory was side offset for all yrs
new mounts will be needed in your case.
check w/ buffalo steve.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=010698#000005
Jim & Caroline
#65338 09/05/2006 3:24 PM
I was not clear. I understand that all 292's have side motor mounts. I was more interested in the "stock" power steering, alternator, & air conditioning brackets. I was also interested if the 292 came from the factory with an automatic transmission. Finally, I wanted to know if this mythical combination of parts came installed "together" on a single car or truck.
carolines truck, I have been watching your build up closely and will continue to do so.
#65339 09/05/2006 10:01 PM
Riding in the Passing Lane
Power streering & auto trans were pretty common but air was very rare. The air brackets from a 250 might fit but pulley alignment might be a problem. The 1 ton trucks 74 up used the power steering pump for the power brakes. It was called hydraboost. Some had the pump on there but didn,t have power steering. The 74 on back had a different system on the front & used wider belts.
1972 Chevy c10 Cheyenne Super
