1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#65282 09/03/2006 10:36 PM
. . apropos of nothing. I have a crankcase vent tube just forward of the distributor right where it should be. Why, then, does the rocker cover have vents in it?
-Mark
1951 3800
-hotshoe
#65283 09/03/2006 11:00 PM
Riding in the Passing Lane
It circulates. The road draft tube pulls air out of the crankase & fresh air enters through the valve cover. 1963 & later used a PCV valve instead of the tube & 1968 up used a tube to the air cleaner instead of a vent on the valve cover.
1972 Chevy c10 Cheyenne Super
#65284 09/04/2006 5:13 AM
It slobbers a bit out of the valve cover vents. is this normal? Doesn't hardly smoke at all out of the tailpipe.
1951 3800
-hotshoe
#65285 09/04/2006 7:50 PM
Yes some can be normal. Make shure your roadraft tube is not pluged up. There might be a latter model cover that uses a vented oil cap instead of the slots.
#65286 09/04/2006 8:44 PM
Right, Wrenchbender. Will do. On another subject, I've installed a primary fuel filter just under the gas tank because a lot of rust was working its way up through the fuel system. This truck has been fitted with an electric (6V) fuel pump, and it had one of those cheapo in-line filters downstream from the pump. I got tired of stopping and flushing everything on the side of the road (at three bucks a gallon). so now I have the two glass inline filters - so I can see what's in 'em, though I'll have to shield the lower one to keep a stray rock from radically affecting my fuel economy (which already ain't nothing to brag about) - and I've bypassed the fuel line from the tank to the carb. that's where the blockages were happening. A temporary fix, but the lines are all tied neatly and safe. On my old truck I had a filter right beside the carb, and it had a removeable glass sediment bowl. I'd like to see another of those one day once most of the crud has worked its way out of the tank.
1951 3800
-hotshoe
