2 members (3B, baldeagle), 105 guests, and 7 robots.
Topics128,014
Posts1,055,328
Members48,419
#65276 09/03/2006 4:18 PM
Found me a distributor in the pile 1112304, nice safe choice fits most 235. The grease cup is empty. So what do you use? Cup grease? Take out the cup and put a zerc in there? How many actually use the cup anyway. I never do, but I know that shaft needs grease of some kind. What's the best way to go?
#65277 09/03/2006 5:50 PM
Just a thought.....you didn't mention what engine you were going to use 1112304 in. You might want to verify that the drive gear matches up with your cam....pre-54's were forged cams, 54's and newer were cast cams.
www.secondchancegarage.com/public/373.cfm has an engine spec page that identifies various components. I browsed their info and couldn't come up with your number.....although 1112403 is a common later-model distributor that fits most applications from 54-60. You might want to check it out.
Can't help you with the specific grease...I use a high temp.general-purpose and very sparingly. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#65278 09/03/2006 9:39 PM
The manual says to use chassis lube. How it works is that you fill the cup, then turn the knob 1/2 turn every 1000 miles.
Bill Burmeister
