1 members (Ponchogl),
322
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65272 09/03/2006 2:18 PM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Has anybody used this product on their vehicles? http://www.ampcolubes.com/index.html Any feedback will be appreciated. Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
#65273 09/03/2006 3:07 PM | Joined: Jun 2005 Posts: 38 Member | | Member Joined: Jun 2005 Posts: 38 | Had a Judson supercharger on my 40hp VW years ago. It had the same style oiler to lube the supercharger. You filled it with Marvel Mystery Oil and the vacuum from the intake sucked it in to lube the supercharger vanes. Never had any problems, except shorter life on the sparkplugs (carbon build up). | | |
#65274 09/03/2006 3:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | We used those 50 years ago. I don,t think it did any good though. When we switched to no-lead gas back in 1975 everyone thought we were going to have all kinds of problems & nothing happened. No-lead seems to work fine unless you have real heavy duty operations. We used to have a lot of trouble running on propane. The valve seats would resess way back in the head, especialy on 300 in. Fords. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#65275 09/03/2006 3:12 PM | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | No and it doesn't make much sense to anyone who understands the combustion process. Oil has a much lower combution point than the type of lead added to gasoline. The "oil mist" would just partially burn and coke up the combustion chamber and exhaust system in a simular way that oil does in two stroke gas and diesel engines. On gas engines oil is mixed with the fuel and on diesel (and some gas) it is due to port leakage.
There are lead substitutes for sale at most auto parts stores. I have no experience with any of them.
Would look pretty could as a period "Snake oyl" piece though.
Having inspected thousands of internal combustion engines, there is nothing that can fix worn out parts except good machine work.
Best advice I can offer is to run it until the valve leakage is unacceptable and then have hardend seat installed.
Jim
Good luck with your project!
