5 members (55shaker, 52Carl, fonz8261, 78buckshot, RoadsScholar), 98 guests, and 4 robots.
Topics128,100
Posts1,056,515
Members48,448
#65272 09/03/2006 2:18 PM
Has anybody used this product on their vehicles?
http://www.ampcolubes.com/index.html
Any feedback will be appreciated.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
Had a Judson supercharger on my 40hp VW years ago. It had the same style oiler to lube the supercharger. You filled it with Marvel Mystery Oil and the vacuum from the intake sucked it in to lube the supercharger vanes. Never had any problems, except shorter life on the sparkplugs (carbon build up).
Riding in the Passing Lane
We used those 50 years ago. I don,t think it did any good though. When we switched to no-lead gas back in 1975 everyone thought we were going to have all kinds of problems & nothing happened. No-lead seems to work fine unless you have real heavy duty operations. We used to have a lot of trouble running on propane. The valve seats would resess way back in the head, especialy on 300 in. Fords.
1972 Chevy c10 Cheyenne Super
No and it doesn't make much sense to anyone who understands the combustion process. Oil has a much lower combution point than the type of lead added to gasoline. The "oil mist" would just partially burn and coke up the combustion chamber and exhaust system in a simular way that oil does in two stroke gas and diesel engines. On gas engines oil is mixed with the fuel and on diesel (and some gas) it is due to port leakage.
There are lead substitutes for sale at most auto parts stores. I have no experience with any of them.
Would look pretty could as a period "Snake oyl" piece though.
Having inspected thousands of internal combustion engines, there is nothing that can fix worn out parts except good machine work.
Best advice I can offer is to run it until the valve leakage is unacceptable and then have hardend seat installed.
Jim
Good luck with your project!
