| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | I just pulled the gas tank out of a '53 one tone that has been sitting in a barn since '74. Obviously rats have taken over the truck and declared a homestead inside. I believe they "[censored] and pooped" on the top of the tank for most of the years. I have sanded, used wire cone on my grinder, and sanded again. I applied Ospho and sanded that off. The top is smooth but not nearly down to original metal. I don't think it ever will get there. I bought a can of Rust Oleum "ColdGalvanized Compound to spray the tank with. IS it ok to spray this on the top over the stuff that I cant remove.
Thanks | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | More important what does the inside look like ,if it's all rusty You might be better off getting a new one.Could the "stuff" be bubbles of metal?
Pete | | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | I think the inside is pretty clean. I put some water in it, swished it around, and when I poured it was very clean. I am going to pour a gallon of carb cleaner in it tomorrow and rotate it around for about a week.
I dont think the stuff on top is bubbles. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Pictures please.  | | |
