1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | My steering box has a little play in it and I want to tighten it up a bit. Is there a way of doing this? I noticed a nut and screw on the inner side of the box that might do the trick but I don't want to mess anything up! Any help would be appreciated.
This is a 55.2 Chevy 3100. All the rest of the front suspension is rebuilt.
Thanks. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | here is a tech article on adjusting the play. i adjusted mine but it didnt help. at some point they just wear out. http://www.stovebolt.com/techtips/saginaw.htmleonard | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Sure hope I don't have to rebuild it, that doesn't look easy. Can you get one of those spring scales at Home Depot or Ace?
Thanks for the info!
Michael | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sporting goods store will have one, aka "fish scale". | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Get a fish scale at Walmart. As Tim said. Then follow instructions. I had this problem with my 55 2nd and it works.
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Thanks guys, I will give it a try. I don't know why I just didn't have it rebuild when it was out of the truck. Guess you can't think of everything!
Tim, In the beginning I wasn't afraid of the unknown, but over the last four years of restoring this truck I have come to respect and fear the unknown!! If I had any idea of what I was getting into I would have just bought (a finished) truck and been done with it, and for less money!
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Thats the easy way out, look at what you have learned!
There is nothing tough about the steering box. Just think about the guy that built it, he did it day in and day out, could probably do it blind folded, you wouldn't him laughing behind your back would you!
Joe | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Are we not supposed to add Ebay links? If so, sorry.
Joe, yeah you're right, I did learn a lot. Spent a lot too. I'm too far in to stop now, must carry on, must carry on. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you are adjusting it in the truck,the shop manual says to disconnect the steering arm from the pitman arm.Follow the directions and you will be fine.I just rebuilt the steering box in the suburban and it wasn't that difficult.
Good Luck,Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
