| | | Forums66 Topics128,051 Posts1,055,705 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65218 09/01/2006 7:45 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | | | |
#65219 09/02/2006 2:11 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Line 'em up with the main caps. Also, the actual idea is to keed the oil pickup submerged during cornering, accelleration, and braking (or popping wheelies!  ). If you do put them in, make sure that you leave a gap at the bottom and possibly a few hole higher up so the oil can flow throughout the pan.
Bill Burmeister | | |
