| | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I couldn't find this specifically with a search. '53 3100, do I need a copper washer between the front brake flex line and steel line? The new flex lines came with 2 washers but they seem to be too large for that connection.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy magfarm51, the copper washers are for a flat seal, such as where a line enters a wheel cylinder, or on each side of a banjo fitting connection to a wheel cylinder or master cylinder, the hard line to flex line connection is usually male to female flare, no washers, hope that helps. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | That's what I thought but needed a confirmation...thanks!
