Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (carbking, 2-Ton, baldeagle, Shaffer's1950, Hanks custodian), 33 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#652028 06/03/2010 4:09 PM
Quick question, can the steering box-column be installed with the front clip on the frame? I have a 53 3100, 3 speed.
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Dave
I think I see what you're asking, you want to know if it can be installed with the frontend sheetmetal in place, correct? If you can gat the truck up on a lift, perhaps, as that would let you slide it up from the bottom. Otherwise, you really should remove at least the drivers side fender and inner spash sheild.
The "front clip" part of your question is somewhat misleading. Most people dont thing "sheetmetal" with the "front clip" term, but rather a front subframe from a Camaro or Nove used to get IFS, which would not work with the stock steering box and column.
Bill Burmeister
