2 members (Roy Rodgers, Peggy M), 109 guests, and 2 robots.
Topics128,042
Posts1,055,518
Members48,424
#651826 06/02/2010 8:58 PM
SPL
Offline
Has someone published a "how to" for installing a new wire harness in a 1949 1/2 ton pickup? I have the harness, a wire diagram and the shop manual but more install info would really help.
SPL #651830 06/02/2010 9:07 PM
What information are you missing? If you are wondering how to access everything under the dash, I have a suggestion. I would suggest you remove the radio grill, then the speedometer and work through the opening.
1951 1 Ton Completed
truckernix #651859 06/02/2010 11:46 PM
Ex Hall Monitor
Ex Hall Monitor
Removing the seat gets you a LOT of room to get under the dash....especially if you're like me and not vertically nor horizontally challenged.
Tiny #651945 06/03/2010 5:15 AM
How difficult is it to remove the speedo and gauge cluster?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #651980 06/03/2010 11:26 AM
The four nuts are sometimes tricky to get at, especially when putting them back on. The other thing with the gauges is the heat and oil pressure lines complicate things a little bit.
SPL
Offline
The old wires were a total wreck and what I need most is how my new harness routes under the dash, across the firewall, around the fenders near the engine and thru the cab and back to the tail lights. I can figure out what wire connects to what device but the right way to get there and where they are clipped is a puzzle.
SPL #652005 06/03/2010 2:36 PM
Is this a show truck or daily driver? You can get it done in a driver truck. A show truck - take your time.
Dennis
SPL #652006 06/03/2010 2:37 PM
any tips on how to remove the seat frame?
aggie jon #652026 06/03/2010 4:05 PM
SPL
Offline
This is a frameup restore but I don't intend for it to be show quality. Can't afford all that.
SPL #652427 06/05/2010 1:43 AM
The original harness under the dash was very tight and so there were no decisions on how to route the harness.
i rewired two trucks so date. like was said earlier remove the speaker grill. i didnt take the seat and frame out nor did i remove the speedo. i did have someone push the clutch to the floor and i vise grip the pedal at the firewall in the engine compartment. i also removed the clevis pin in the master cylinder and got the brake pedal out of the way. with both pedals out of the way it was easy for me to get in up under the dash. depending on whose harness you purchased which really shouldnt be much differece than any other harness thats made.
before i get started i lay out the harness as it sits in the truck. i trace out all the circuits and mark both ends as to where they go which will get you familar with how it goes once you actually strat to install it. carefully feed the main part of the harness thru the hole in the fire wall until you get to the first splice in the harness. use the wires that go to the voltage regulator as your guide as to how far to feed into the cab. there are two bendable tabs under the dash that holds the harness in place. locate them and put the harness in the first on and then feed the remainder over towards the center of the dash. then start hooking up the wires to the proper terminals. when your done in the cab then lay out the remainder of the harness in the engine compartment using the clips on the inner fender to hold in place. i like to do the voltage regulator, dimmer swich which i find its easier to remove the switch, hook up the wires then put the switch back in. horn and geeny are next followed by the head/park lights but you can do it anyway you find to be easiest for you. i wire up the brake light switch after i hook the pedal back up to the master cylinder and release the clutch pedal.
main thing is to have all good cleaned terminals and grounds with tight connections. its not fun chasing down non working circuits after you go through installing a new harness.
