| | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 12 New Guy | | New Guy Joined: Mar 2010 Posts: 12 | I have two 15 inch 6x5.5 wheels on the front of my '50 3100. I am woundering what the could have came off of? they have the clips welded on them to accept center caps. I am in need of two more of these wheels and dont know what vehicle they came off of.
Thanks | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | might be wrong but i think those are stock i have a few of those round my place "but i am in okla" lol shipping might be a pain
1937 1/2 ton
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if they fit your stud bolt pattern then they came from an old Chevy truck, although there was some years of Toyota truck that used the same pattern .... the original clips were riveted, welded wouldn't be from the factory, so maybe they're Toy wheels someone added clips to, in which case you should find a correct set  Bill | | | | | Joined: Mar 2010 Posts: 12 New Guy | | New Guy Joined: Mar 2010 Posts: 12 | the clips are riveted on. what years chevy trucks used these? I can only seem to find 16's | | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | most likely they came from a chevy car like mine did | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the cars had 5 lug wheels Bruce, and the front hubs interchange early car to truck, but if you've got 5 lug wheels on the back the rear end isn't original
all years of trucks had 15's and 16's - most years the 15's were the base equipment with 16's optional for slightly higher GVW .... if your wheels have 6 hub cap clips they're pre-55, after 55 they had 3 clips until 60
widen your search, any year truck will fit the lug pattern and up to 1960 have the hubcap clips, later 15's into the 70's also fit and you can add the clips
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What was the last year that cars had 6-lug wheels? Standard 1948 car wheels were 16" and had 6 lugs (15" 6-lug car wheels where also available this year). As Bill posted, during all Advance-Design years, 6-lug 15" wheels were available on 1/2 ton trucks; however, the 15" wheels were optional and the 16" wheels (6.00x16", for all years) were standard (at least on USA trucks: 1948 truck wheels and 1954 truck wheels). | | |
