9 members (tclederman, 57 Drifter, baldeagle, Cosmo, Paul_WNC, Bill Hanlon, gswbbc, HandyAndy, 1 invisible),
181
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | I'm replacing the wood in my trucks bed. What would happen if I didn't route the edge of the board for the wear strip? My thought was to just bolt the wear strip over the unrouted boards. My truck has a fleetside bed, will the wheel wells fit? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The " routed " edges serve a couple of purposes. The groove in the edge allows the boards to move a little without going too far either direction. Also recesses the wear strip so it does not interfere with loading/unloading bed. Grooving is pretty easy. I used a couple of passes with a Table Saw. | | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | What kind of blade did you use on the table saw. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Just a good quality finishing blade - Carbide tipped works well. Inside cut is slightly deeper than rest - make it first, then work your way out to edge by moving saw fence a little each time. Practice on a scrap piece first. Have a look at the Mar-K site here - I think it has dimensions for grooves. | | |
