5 members (Otto Skorzeny, 2-Ton, Wally / Montana, Lightholder's Dad, 1 invisible), 117 guests, and 0 robots.
Topics128,051
Posts1,055,730
#651435 06/01/2010 4:49 PM
I'm replacing the wood in my trucks bed. What would happen if I didn't route the edge of the board for the wear strip? My thought was to just bolt the wear strip over the unrouted boards. My truck has a fleetside bed, will the wheel wells fit?
blue67fleetside #651451 06/01/2010 5:37 PM
The " routed " edges serve a couple of purposes. The groove in the edge allows the boards to move a little without going too far either direction. Also recesses the wear strip so it does not interfere with loading/unloading bed. Grooving is pretty easy. I used a couple of passes with a Table Saw.
1940 Chevy KC 1/2-Ton
Britcon #651465 06/01/2010 6:04 PM
What kind of blade did you use on the table saw.
blue67fleetside #651656 06/02/2010 7:11 AM
Just a good quality finishing blade - Carbide tipped works well.
Inside cut is slightly deeper than rest - make it first, then work your way out to edge by moving saw fence a little each time.
Practice on a scrap piece first.
Have a look at the Mar-K site here - I think it has dimensions for grooves.
Britcon #651851 06/02/2010 10:38 PM
If you are looking for help on how to cut your bed wood, here is the link:
http://www.mar-k.com/bedwooddimensions.pdf
Here is one on drilling the mounting holes:
http://www.mar-k.com/drilling_mounting_holes.html
Hope this helps!
