7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible), 56 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
I just bought a 50 five-window. I decoded the engine to be a 1958 235.
I can't find any where to decode the trans and rear. trans is a 3 speed on column and rear is supposed to be original.
The trans numbers are as follows:
GM
691816
HR214789
H190
The rearend numbers are:
HE1025 and 3657339
Thanks for your help!
HR214789 : HR = 1950 Muncie?
HE = 1950 3100 regular rear end?
http://chevy.oldcarmanualproject.com/chevyresto/5052.htm
H190
H = August
18 = 19th
0 = 1950
Thanks Tim, that was the link I was looking for.
Looks like rear end was built Oct 25th, which makes sense since trim plate shows truck built in Nov.
Could that Muncie be original, with the August date? Also looks like it may of came from a 3600. Mine is a 3100.
Chad,
I also do not understand the 3600 transmission. Maybe someone else will look at this and correct/clarify.
Maybe Im reading it wrong. Looks like HR is in the 3600,3700 column.
I agree.
chad,
Can you recheck that trans. casting #691816.
I think a 50, 3 speed casting should begin with a 5.
Something like 591615.
-Tom
1950 Chevy 3100 w/ 1956 235
