6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
I have a back-up light switch set-up for my 4-speed trans. I removed it from another truck that I junked years ago. Are these rare? Does anyone have one on their truck? I need a close up picture of the actual switch that mounts on the bracket, as I have everything but the switch assy., and will need to retrofit some sort of switch. Can anyone help me out? Thanks!
With your e-mail address, I will send you a photo.
I had a post in here awhile back about these. I have mine, but unfortunately the plastic guts in it are broke, and I managed to loose part of them. Someone responded with a switch thats available at Radio Shack, but after looking at one, it definately needs to be modified somehow. If someone has a location for these, I would also be interested.
I have a four speed car transmition in my 64 with a Hurst shifter. I used switch # 7343K751 from McMaster-Carr. It is a 15 amp, spdt switch and I built my own bracket to mount it. Works great.
