1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65083 08/30/2006 9:26 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | I have the restoration kit, and I'm trying to decode the engine number. The number, behind the distributor appears to be FI02bJ which doesn't really match up to anything unless I'm misreading the number. It really does not look like F1026J, which would translate to Flint, Michigan, October 26, Base Engine on CK, 10-20, C30. Picture here: Engine Number My truck is a '61 K10 with a 235.
1961 Chevrolet K10
#65084 08/31/2006 12:35 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's a good picture of the number. The number on my 38 doesn't look like that so I can't help in that respect but it would not surprise me at all if F1026J is correct. If that is the correct number location & FI02bJ is jibberish it almost has to be correct.
#65085 08/31/2006 12:47 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think that the "b" is actually a mis-stamped "5".
Bill Burmeister | | |
#65086 08/31/2006 4:58 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is clear from your picture (raised casting number) it was cast the second day, unknown month, 1961. Would need the letter before the 2-1 to know the month.
See the USA in your vintage Chevrolet! My Blog | | |
#65087 08/31/2006 3:09 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | Originally posted by Pre '68 Dave: It is clear from your picture (raised casting number) it was cast the second day, unknown month, 1961. Would need the letter before the 2-1 to know the month. Here's a better picture: Casting
1961 Chevrolet K10
#65088 08/31/2006 3:59 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The F = June 12 1961, The J suffix in your stamping shows up as a Thriftmaster 235
