2 members (Rich'sToys, 1 invisible),
65
7
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | Has anyone performed the wheel conversion described in the tech tips section or something similar? I have the 18x5 split rim wheels with the 7.00-18 tires and it is going to cost $12-1300 dollars for new tires. I am hoping to do it for half that and so I'm looking into changing the wheels. Which, would be more expensive, if I went new. But I'm researching if I can get 6 wheels/tires for less than 6 bias-ply tires. Basically what the tech tips describes for 1 tons with this wheelset is a a direct, modern replacement. The tips suggests using 8-lug dual 19.5" wheels from a 1975-99 “step van” and 8R19.5 tires (radial). Has anyone successfully converted this way? Of course the cost is dependent on what can be found, but any idea of total costs incurred for the conversion? I'll post my results as I have them! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check the clearance between brake drums and the new wheels, if they clear you're good to go.
Grigg | | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | Ok, I found a place that has some 19.5" wheels. What is the best way to check the fit? Drive the truck out there, jack up a wheel, pop the old one off and try out the new? I'll deal with tires after I get the wheels as the wheels are obviously more important.
I can't run the 19.5" radial in the front and the old 18X5" on the duallies can I? My instinct is no, but if they're direct replacements, maybe it is a possibility??? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't like mixing radial and bias ply tires. It can lead to strange handling behavior. Better to run the same design tire front and rear.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | Ok. I'll see if they fit and if I can't buy all 6 (or 7) at once, I'll just wait for the full set. Might something like this work? It's an ebay link for 19.5" wheels.
| | | | | Joined: Nov 2009 Posts: 1 New Guy | | New Guy Joined: Nov 2009 Posts: 1 | I currently have a 57 and 56 dually, I bought some 19.5 wheels from an old frito lay truck they would not clear the rear brake drums without spacers. Also the stud size for the newer rims are larger. I plan to install a cab and chassis rear axle in both trucks | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Switching to 19.5's good move ! my 62' GMC came with 19.5's i love them best tires i have ever ran i loved them s much i put a set on the F350, and kicking around the idea of tossing a set on the K2500 . . .
Can't go wrong with 19.5's !
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | I have a set of 19.5's with Michelin 8R19.5 rubber on my 50 GMC 1 Ton, you will not be disapointed at all. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I have a set of 19.5's with Michelin 8R19.5 rubber on my 50 GMC 1 Ton, you will not be disapointed at all. Could you send me a picture of your truck on those tires? I'd love to see what it looks like on 19.5's. Any idea on the original vehicle they are from? | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | I love the 8-19.5's not the biggest fan of the 8R19.5's they seem to run a bit short and they don't offer mudder's, well heck neither dose the 8-19.5's any more. . .
Mike
| | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | I will send a photo of my 1950 GMC 250 1 Ton if you give me your direct e-mail, to hard to post on site ? Also the 19.5 fit the GMC perfect ! People make a big deal about the different hole pattern but I think the improvement in wheel design & tire choise is worth the trade off.....gmguy | | | | | Joined: Sep 2011 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 65 | Hey gmguy, I have a 1949 GMC FC253 1 Ton as well. My 19.5's are hitting the drum brakes in the rear. Any thoughts of what can be going on? I posted a new thread on this as well. Just spent a good amount on the rims and a nice set of used tires and will be really bummed if I can't use them! Been looking around for drum brake swaps too  . Any help would be appreciated. Thanks, Greg
1949 GMC FC253 - 1 Ton Dually 1966 Buick Wildcat Convertible
| | | | | Joined: Nov 1995 Posts: 5,713 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,713 | Does any of this apply to the 3804 crowd? (SRW) I'm assuming it does not ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The single rear wheel 19.5 wheels fit perfectly. The dual wheel 19.5 some wheel designs will no fit the 48-54 or so with 14” rear drums. Many of these 19.5” dual wheels do fit. | | |
