5 members (frogfarmer, JW51, treegrower, Charles in CA, 1 invisible), 47 guests, and 3 robots.
Topics128,074
Posts1,055,910
Members48,429
#65047 08/30/2006 8:35 AM
Can somebody who has yanked their closed driveline transmission measure how long the input shaft is? I don't have mine out yet, but will need this info for making an adapter plate. A measurement from the flat surface that mates to the bellhousing to the tip of the pilot shaft is what I need. I know a bunch of you are running T-5s, and have your original transmissions laying around the barn somwhere...
#65048 08/30/2006 9:01 PM
4speed is 8 3/16 from end of shaft to mating surface on trans.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#65049 08/30/2006 11:30 PM
sh** I was expecting it to be around 6 1/2 inches. How long are the T-5s?
