| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65040 08/29/2006 10:14 PM | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I was wondering if there was another way to remove the camshaft from a 216 engine? In the Chevy 1941 shop manual it states you need a camshaft bearing removing & replacing tools. I am just tinkering with the motor, no plans to rebuild. Thanks James
If it was easy, everybody would be doing it.
#65041 08/29/2006 10:23 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James B,
The camshaft is quite straightforward to remove.
The camshaft BEARINGS are another matter. These are two different animals. Although R&R'ing the cam bearings isn't rocket science, it takes the proper drivers and a pretty good level of skill.
Cam bearing removal and installation usually follows a boil job at the local automotive machine shop...they do this chore all the time!
Stuart | | |
#65042 08/29/2006 10:27 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | The bearing removal tool can be rented at some parts houses. If you are not intending to O/H the engine I would'nt worry about the camshaft. Do you now had compression problems or knocking noise? If no, then there is no reason to monkey with the camshaft. If you want to just give the camshaft a look, that can be done with out replaceing the bearings. So no special tools are required.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#65043 08/30/2006 9:21 PM | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | thanks for the info. I just want to remove the camshaft from the block.
