8 members (Robert Crandall, Wayne67vert, Uncles51, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps), 79 guests, and 2 robots.
Topics128,041
Posts1,055,480
Members48,424
#65040 08/29/2006 10:14 PM
I was wondering if there was another way to remove the camshaft from a 216 engine? In the Chevy 1941 shop manual it states you need a camshaft bearing removing & replacing tools. I am just tinkering with the motor, no plans to rebuild. Thanks James
If it was easy, everybody would be doing it.
#65041 08/29/2006 10:23 PM
James B,
The camshaft is quite straightforward to remove.
The camshaft BEARINGS are another matter. These are two different animals. Although R&R'ing the cam bearings isn't rocket science, it takes the proper drivers and a pretty good level of skill.
Cam bearing removal and installation usually follows a boil job at the local automotive machine shop...they do this chore all the time!
Stuart
#65042 08/29/2006 10:27 PM
The bearing removal tool can be rented at some parts houses. If you are not intending to O/H the engine I would'nt worry about the camshaft.
Do you now had compression problems or knocking noise? If no, then there is no reason to monkey with the camshaft. If you want to just give the camshaft a look, that can be done with out replaceing the bearings. So no special tools are required.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#65043 08/30/2006 9:21 PM
thanks for the info. I just want to remove the camshaft from the block.
