4 members (FAST55, lumbersawyer, tclederman, 1 invisible), 73 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#650214 05/27/2010 8:20 PM
I am having problem shifting in all gears in my '53 3100 3 speed.....sometimes is 1st and reverse...other times it's 2nd and 3rd.....other times it's all gears. Any types to get me started? Someone explain the details of double clutching....keep in mind I'm a cop...type slowly.
With the problem being bunched in the pairs of gears as described I would suspect the shifter linkage. Probably worn out bushings.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I'm a disabled guy so I already type pretty slow. I hope I can slow down enough more you can read this.
A '53 3-speed should not need to be double-clutched. You should have synchros for every shift except into 1st or reverse. I'd start by checking the lubricant in the transmission. First does it have any, and assuming it does, is it clean?
If the lube is okay I'll have to let someone else take the lead on your questions because I know little about transmissions.
The shifter linkage bushings....are those on the steering column or the actual joints in the shifter linkage?
OldSub #650237 05/27/2010 9:26 PM
I have fresh 90W in the trans....could the syncros be bad?
Riding in the Passing Lane
If it clashes when you shift it is the syncros. If you have trouble shifting & finding gears it is in the linkage &/or the shift box on top of the column. That little box often gets worn inside . They are easy to rebuild. You can weld up the worn places & file or grind them back. You can sand down the surface of the cover to take up for wear in the shaft holes.
To double clutch if you are down shifting you put the clutch in & shift to neutral, let the clutch out & accelerate the engine to the rpm it will be at when you complete the shift & put the clutch in & complete the shift. To up shift you put the clutch in, shift to neutral let the clutch out & hesitate till the engine slows to the speed it will be after the shift. Then put in the clutch & complete the shift. You can downshift to first before you stop using that method.
OK now if I charge by you in my 58 pickup at 80 mph you will not give me a ticket. George
1972 Chevy c10 Cheyenne Super
Another problem solved on Stovebolt...bushings are shot. Where can i find the bushings?
I believe THESE are the ones.
You may also want to replace THIS while you are at it.
Actually look about 70% of the way down on THIS page.
1953 Chevrolet 3600
