| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I am having problem shifting in all gears in my '53 3100 3 speed.....sometimes is 1st and reverse...other times it's 2nd and 3rd.....other times it's all gears. Any types to get me started? Someone explain the details of double clutching....keep in mind I'm a cop...type slowly. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | With the problem being bunched in the pairs of gears as described I would suspect the shifter linkage. Probably worn out bushings. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm a disabled guy so I already type pretty slow. I hope I can slow down enough more you can read this.
A '53 3-speed should not need to be double-clutched. You should have synchros for every shift except into 1st or reverse. I'd start by checking the lubricant in the transmission. First does it have any, and assuming it does, is it clean?
If the lube is okay I'll have to let someone else take the lead on your questions because I know little about transmissions.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | The shifter linkage bushings....are those on the steering column or the actual joints in the shifter linkage? | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I have fresh 90W in the trans....could the syncros be bad? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it clashes when you shift it is the syncros. If you have trouble shifting & finding gears it is in the linkage &/or the shift box on top of the column. That little box often gets worn inside . They are easy to rebuild. You can weld up the worn places & file or grind them back. You can sand down the surface of the cover to take up for wear in the shaft holes. To double clutch if you are down shifting you put the clutch in & shift to neutral, let the clutch out & accelerate the engine to the rpm it will be at when you complete the shift & put the clutch in & complete the shift. To up shift you put the clutch in, shift to neutral let the clutch out & hesitate till the engine slows to the speed it will be after the shift. Then put in the clutch & complete the shift. You can downshift to first before you stop using that method. OK now if I charge by you in my 58 pickup at 80 mph you will not give me a ticket. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | Another problem solved on Stovebolt...bushings are shot. Where can i find the bushings? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I believe THESE are the ones. You may also want to replace THIS while you are at it. Actually look about 70% of the way down on THIS page.
