| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65014 08/29/2006 5:26 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | hey guys i dont know much about rear ends and transmissions but i have got to save some money on my gas bill!
my current setup is the drive line from a 79 caprice. 305v8 (supposedly has a R.V. cam), th350, and 10bolt chevy 2.56:1 rear end (thats the specs from a website)
now what concerns me is that i do a lot of highway driving, 35 miles a day, and the th350 shifts into 3rd at 40-45mph... i dont have a tach but im not comfortable driving any over 60mph... just feels like im dogging it out.
any suggestions? different gears? an over drive? i want this truck fun and quick but also comfortable on the highway. | | |
#65015 08/29/2006 6:02 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | the 2:56 should be good for the hiway.. why cant you drive it over 60.......the shift points dont seem that bad off but it has been a long time since I drove a 350 auto........... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#65016 08/29/2006 6:48 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | I can drive it over 60, hell ive had it over 80, it just seems to be running too high rpms, dont want to beat the crap out of it. maybe im just being paranoid? this is my first auto trans in many years perhaps im too used to being in control of 4+ gears manually??? | | |
#65017 08/29/2006 8:22 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Are you sure it's a 2.56 then? Have you jacked up the rear end and counted wheel rotations to drveshaft rotations or counted the teeth? Good Luck. | | |
#65018 08/29/2006 8:26 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | colin... no not sure. can you further explain ways to determine what ive got. thanks | | |
#65019 08/29/2006 9:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | With a 2.56 rear end you should be loafing down the highway. Pull the cover off the rear end & get the numbers off the edge of the ring gear. It will have something like 36-9. Divide the large no. by the small no. & you have the ratio. 2.56 would be an ideal ratio in that combo for highway use. A 305 won,t hardly pull anymore than that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#65020 08/30/2006 3:40 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a collection of pieces from a '78 Monte Carlo that are similar to what you describe. 305, 350 turbo and 2.29 rear gears. This setup had 70 series series tires on 14 inch wheels and when I drove it, before taking it apart, it seemed to work reasonably well.
What tires are you running? Your effective ratio is taking tires into account may be so high that your motor is lugging going down the highway at 60. Find one of the ratio calculators and check it out.
You don't need an overdrive to make this truck race down the highway. If it won't do it now you either need more power or lower gears, not higher.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#65021 08/30/2006 3:25 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | good point old sub. im running stock size 63 chevy truck wheels/tires. 15inch 7wide... forget the heigth... same as the front. I assume the rear end is the stock from the 79 caprice because the rear drum brakes are as well, had to play the guessing game on searching for replacement brake cylinders). after i insulated the cab with peel & seal and double foil bubble wrap its much quiter now and not seeming so bad. the part im still a little concerned about is shifting into 3rd at 35-45mph... is that ok or normal? if not how do I go about changing w/o a shift kit? somethign with the vacuum to the trans??? planning on a new tach install this weekend and that should show me whats really going on and put my mind at ease hopefully.
thanks for the info guys | | |
#65022 08/30/2006 6:19 PM | Joined: Feb 2000 Posts: 5,209 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,209 | With big enough tires and a true 2.56 gear ratio, 35 to 40 may be right. Are you using the kick down cable on the turbo 350? If you are try unhooking it, it won't hurt a thing, just won't down shift. But if the cable is hanging up, it fool the trans into shifting late. It should be shifting sooner when driving very easy, get that tachometer hooked up and let us know some rpm shift points and cruize rpms. Joe | | |
#65023 08/30/2006 8:28 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | kick down cable is not hooked. would hooking it up help anything? i dont know much about the function of them suckers | | |
#65024 08/30/2006 10:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The cable on a 350 is for kickdown (passing gear). The vacuum modulator controls the shifting. Replacement mods. have a tiny adjustment screw inside the vacuum opening. It doesn,t change a whole lot though. This doesn,t apply to 200-4r or 700-4r. The cable adjustment has to be perfect on these. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#65025 09/01/2006 7:39 PM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Troy- Sounds like you have a way higher rear gear than a 2.56 My '67 has a Turbo 350 and a 3.73 rear end ration. At 70 mph I turn about 3100 RPM. Way too high for today's gas prices. My plan is to install a 700R4 overdrive which will bring the cruising RPM down to 2100. That is in the range my '95 Silverado had and it had excellent power and mileage. Here is an excellent link to help you decide on gearing and so forth. It accounts for tire size, tranny and all the variables. http://www.classictruckshop.com/garage/shopmathgearcombo1.asp Good Luck! _________________ Guy _________________ '67 C-10 283/350 | | |
#65026 09/02/2006 3:16 PM | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | Thanks for the page Guy. I like the extra info on other possible gear ratios, accross the bottm, once youve calculated for your stated combo. - MV | | |
#65027 09/03/2006 3:25 AM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Best one I have seen so far - there are several out there but this one seems to work the best.
You can run through a ton of "what if" scenarios in just a few minutes. Sure is a lot easier than swapping parts till you get it right!
Love your project - keep us posted on the progress...
______________________
Guy
