7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl), 109 guests, and 0 robots.
Topics128,051
Posts1,055,764
#649987 05/27/2010 1:17 AM
62401
Are 261 push rods the same as 235 push rods?
A fellow here in town has a 235 that's in the final stages of being rebuil;t and needs 2 push rods. I have my 261 squirreled away -- If they're the same, I'll give him two out of my 261 to get him on the road and then he can find me two more later at his convenience.
Will it work?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Could be. There are 2 types that I know of. The thin ones that I associate with early engines and the tube type ones that I've seen on later emgines. They are the same length, the only difference is in the size of the cup at the top that the adjuster screw fits into. These are different from each other. That being said if you take hime 2 push rods and 2 nuts and screws from your rockers everything should interchange and work just fine. You don't want to use the wrong adjusters on the wrong push rods, the rods will break fairly soon. Don't ask me how I know.
54Monster
what year is the 235. there are two different lengths
i dont know if the 261 rods will fit in the 235 but there are at least two different legnths of 235 push rods. shorter for the solid lifters and longer for the hydro.
If the engine he is working on has been modified any at all, it is also possible that he could have the short lifters or the taller lifters. The height of the lifters will affect the length of the push rods and that could be what "monkey wrench is talking about.
