| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Are 261 push rods the same as 235 push rods?
A fellow here in town has a 235 that's in the final stages of being rebuil;t and needs 2 push rods. I have my 261 squirreled away -- If they're the same, I'll give him two out of my 261 to get him on the road and then he can find me two more later at his convenience.
Will it work?
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2007 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 41 | Could be. There are 2 types that I know of. The thin ones that I associate with early engines and the tube type ones that I've seen on later emgines. They are the same length, the only difference is in the size of the cup at the top that the adjuster screw fits into. These are different from each other. That being said if you take hime 2 push rods and 2 nuts and screws from your rockers everything should interchange and work just fine. You don't want to use the wrong adjusters on the wrong push rods, the rods will break fairly soon. Don't ask me how I know.
54Monster | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | what year is the 235. there are two different lengths | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i dont know if the 261 rods will fit in the 235 but there are at least two different legnths of 235 push rods. shorter for the solid lifters and longer for the hydro. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | If the engine he is working on has been modified any at all, it is also possible that he could have the short lifters or the taller lifters. The height of the lifters will affect the length of the push rods and that could be what "monkey wrench is talking about.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
