| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | hi friends, i have a 65 gmc that had a 230 6 cly in it. i replaced it with a 283. i ordered the wiring harness for engine bay from brothers so i could plug up my new hei dist. the truck cranks right up with switch but will not shut off. i didn't have this problem until i changed engines.I have tried chaning the two wires in the harness around. one way it will not even crank. whats could be going on? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It's not the wires to the starter, your wire to the distributor is staying hot. That is the one that shuts off the engine. | | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | thanks alot. what is the best way to solve the problem. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You will need to figure out why that wire is hot all the time. Did you buy a stock under-hood harness and plug it into the six cylinder harness at the cab? Consult the wiring diagrams in the repair manual and you may be able to identify the problem. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | I ran my hei wire directly from my switch. Make sure you use the right gauge wire. 10 or 12 I think and soder it right to the hot keyed side of your switch. I think I posted on here a while back and that was what I was told to do. You don't want it fused because it could blow at the wrong time. | | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | I just got through running the wire from hei to switch. worked great. thanks to you guys and this forum. should have asked sooner. | | |
