4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 37 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#649638 05/25/2010 8:47 PM
rar
Offline
hi friends, i have a 65 gmc that had a 230 6 cly in it. i replaced it with a 283. i ordered the wiring harness for engine bay from brothers so i could plug up my new hei dist. the truck cranks right up with switch but will not shut off. i didn't have this problem until i changed engines.I have tried chaning the two wires in the harness around. one way it will not even crank. whats could be going on?
rar #649641 05/25/2010 8:51 PM
It's not the wires to the starter, your wire to the distributor is staying hot. That is the one that shuts off the engine.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
rar
Offline
thanks alot. what is the best way to solve the problem.
rar #649649 05/25/2010 9:22 PM
You will need to figure out why that wire is hot all the time. Did you buy a stock under-hood harness and plug it into the six cylinder harness at the cab? Consult the wiring diagrams in the repair manual and you may be able to identify the problem.
1953 Chevrolet 3600
I ran my hei wire directly from my switch. Make sure you use the right gauge wire. 10 or 12 I think and soder it right to the hot keyed side of your switch. I think I posted on here a while back and that was what I was told to do. You don't want it fused because it could blow at the wrong time.
61nate #649750 05/26/2010 3:36 AM
rar
Offline
I just got through running the wire from hei to switch. worked great. thanks to you guys and this forum. should have asked sooner.
