3 members (TooMany2count, Rich'sToys, 1 invisible), 74 guests, and 7 robots.
Topics128,021
Posts1,055,353
Members48,420
#64957 08/28/2006 5:58 PM
Hello , I am replacing my temperature gage and cannot get the old sensor out of the engine. I have the brass hollow bolt that holds it in place out but can't budge the sensor. Any suggestions ?
#64958 08/28/2006 7:28 PM
It's OK folks I got it out!I just wasn't prepared for the "old Faithful "show.
Anybody know what a 216 runs at temperature wise?
I have a 160 thermostat . Thanks, Jeff
#64959 08/28/2006 7:39 PM
Ex Hall Monitor
Ex Hall Monitor
grin I wasn't prepared either. Mine runs at 180 deg unless I'm going slow on a hot day. A 160 certainly won't hurt anything.
#64960 08/28/2006 10:23 PM
So far mine is running at around 140 F according to the WallMart gage I installed this morning.
I did have the rad completly re cored a few weeks ago and everything is running fine.I'll save up and get the new gage for the original cluster one of these days.Jeff
#64961 08/29/2006 2:00 AM
my 216 runs at 180 on the road here in N centeral texas when the days don't exced 95,if it gets to 100 the temp may go to as much as 220 while ideling. I have a 180 degree thermo in it and it runs fine,how ever I think that my guage may read obout 10 degree high and I need to adjust it.
#64962 08/29/2006 3:30 PM
Kind of depends on the thermostat you are using. You Will need a gauge that centers around 180 if that is your question.
"It ain't a truck if you can't hose out the cab."
