1 members (69Cuda),
73
Mod | | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | I have a 1950 Chevy 3100 Thriftmaster 1/2 ton, which is supposed to have a 216. I looked at the Old Car Manual Project web site - http://chevy.oldcarmanualproject.com/models/engine.htm but couldn't identify the engine serial number. The engine I have says "DR140622CAL", which is different from the serial number layout on the above site site. Is there any other sources engine serial number searches? The other interesting fact, is that everyone, including the old timers, has told me that the 1950 216 has babbitt bearings, which I understand to mean that the bearings are integrated into the piston rods and crankshaft main bearings. When I pulled one of the rod bearing caps off it had a bearing insert. I also under stand that the 1950 216 engine was a light blue color like the engine compartment, but the engine is orange. I'm wondering if the engine is a different year? Like I said above, I'd like to track down this engine serial number | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | There should be a letter and numbers stamped on the block, right side, to the rear of the distributor that can be deciphered to give you the year your engine was cast.
If I remember correctly, the date code is: A=Jan, B=Feb, and so on. The next number is the day of the month the block was cast. The last number is the year it was cast. For example, my engine says F 3 7, which means it was cast June 3, 1957. I found out the decade by matching the numbers stamped on the intake manifold to a list noting the year they were made. There's one that says GM (folllowed by numbers). That's not it. The other one says "something like" 383etc. etc. etc. That's the one. So, since my number said the manifold was cast between 1956 and 1962, I knew the engine was a ninteen FIFTY seven.
Sadly, I don't remember where I got the manifold intake data. But I'm a newbie my own self and I puruse these forums on midnights. The guys who know their business will be awake in a while and will be able to correct my info and/or give you eveything you need to know.
But, if you're awake, and feel like lookin' around, that'll keep you busy for about five minutes.
Oh yeah- use SEARCH just to your left. It's got all sorts of info on past posts. Try something like "engine ID".
Good luck to you, D Winn! | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Not sure how, or where, to post pictures. As I mentioned above, the metal tab on the right side of the block, to the left of the distributor says "D R 1 4 0 6 2 2 C A L". I spoke to a friend at church this morning that's been helping me some and he said the engine definitely has insert bearings as opposed to babbitt, which makes him think it's a later replacement engine. | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Just went out and found the casting numbers, and then checked them on line; 216 inline head casting #: 1950-53 3835517 All 216 216 inline block casting #: 1952-53 3835849 216 Passenger, Truck
Another source fro the block casting #: 52 AKCA. AKCM, BKCA, BKCM, KAA, KAM, KAC, KAP, KBA, KBM, KCA, KCM, KCD, KCQ 3835849 53 ALCC. ALCP, BLCC, BLCP, LAG, LAT, LAJ, LAV, LBA, LBM, LCA, LCM, LCC, LCP, LCD, LCQ, LCH, LCU 3835849 Makes me think it's a 52/53 engine. Where do the prefix letters come into play? Still baffled by the DR140622CAL serial number. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | D Winn says.... makes me think it's a 52/53 engine.
No need to guess. The block casting date code is on the same side, down where you found the block casting number.
Not the CON 1, the other one. The last digit is the year.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Does your engine have a side cover that stops at the top of the block? If so, look at the passenger side of the head. Is there a bulge in the casting between #5 and #6 spark plugs and also between #1 and #2? If so, it would be the motor that was used between 1950 and 1952, I would think. It would also be low pressure. | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Here's a reply I received concerning the serial number, which I received from another forum where I asked this same question. Yes your "DR " number is a asigned ID number. Many years ago many states used both engine and chassis ID numbers on titles. So you got a GM new replacement or reman engine you had to go down to the DMV and get it inspected and the title corrected. Dad replaced the engine in our 41 Chevy in 51 and down to DMV we went. Most car makers stopped using engine IDs towards the late 50s and states started using just the chassis ID on title. I'm pretty well convinced that the the 50 truck has a 52/53 216 engine. When getting parts I'll probably treat it as a 52 or 53 engine. I will go look for the casting date code. | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | What would the casting date look like and where would it be in relation to the casting code? Above the block casting code, which is "3835849", I see a "GM 3". May have to clean off some more crude! | | |
