8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
' Offline
I have a Mustang II front end with a bolt pattern of 5 @ 4 1/2". My '70 F100 Rear End currently has axles with 5 @ 5 1/2". I'm having new axles made that will match the front and will also be 5 @ 4 1/2". Does anyone know what brake drum will work with the new 4 1/2" pattern? I need an 11" drum that'll take 2 1/2" linings. The overall heigth of the drum is 3 3/4". I suspect several of you guys have done the same so thought I would ask and not reinvent the wheel (or drum in this case).
Try looking at full size ford passenger car drums.
Bill Burmeister
Can drums be re-drilled ?.....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
The drums can be redrilled right along with your axle mods.Had mine done at Moser Engineering in Indiana.
had my pacer rotors done by a friend who owns a machine shop...wasnt for sure about the drums though.....dave
1949 Chevrolet 3100
