0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | I have a Mustang II front end with a bolt pattern of 5 @ 4 1/2". My '70 F100 Rear End currently has axles with 5 @ 5 1/2". I'm having new axles made that will match the front and will also be 5 @ 4 1/2". Does anyone know what brake drum will work with the new 4 1/2" pattern? I need an 11" drum that'll take 2 1/2" linings. The overall heigth of the drum is 3 3/4". I suspect several of you guys have done the same so thought I would ask and not reinvent the wheel (or drum in this case). | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Try looking at full size ford passenger car drums.
Bill Burmeister | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Can drums be re-drilled ?.....dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The drums can be redrilled right along with your axle mods.Had mine done at Moser Engineering in Indiana. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | had my pacer rotors done by a friend who owns a machine shop...wasnt for sure about the drums though.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
