1 members (CuzzFuzz),
228
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#6480 06/27/2004 11:46 AM | Joined: Apr 2004 Posts: 19 Junior Member | | Junior Member Joined: Apr 2004 Posts: 19 | Good morning fellow Bolters. I am looking for any info on the modifications to the steering column for my '65 4x4 Burb when I install a mid 80's front axle w/ disc brakes this week. Any info is appreciated. Have a good 4th and Bless our troops. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Swampratt,, what steering box do you have now? power or manual? You can make nearly any steering column fit with a little fab work
| | | | | Joined: Apr 2004 Posts: 19 Junior Member | | Junior Member Joined: Apr 2004 Posts: 19 | I currently have the original manual box but the old beast really needs to go to power steering. I will start locating all of the brackets this week for the power steering, so any info for this application would help. Thanks! | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Be sure to get the reinforcement plate that strengthens the frame where the steering box mounts. Are you going with a lift? If so, How high? May want to think of going with a 2wheel drive steering box so you can go with a cross-over steering (tie-rod steers from the right side and helps a lot to eliminate bump-steer when 4-wheelin`  .
| | | | | Joined: Apr 2004 Posts: 19 Junior Member | | Junior Member Joined: Apr 2004 Posts: 19 | I appreciate the help. The old Burb has been in the family since new but has never been off-road, but your suggestion with the 2 wheel drive box will be used. The donor truck for the front end has a 4in. lift so I will probably go ahead and put the old Burb up in the air. Thanks again and have a good 4th. | | |
