| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64836 08/25/2006 4:39 PM | Joined: Jul 2006 Posts: 3 Junior Member | | Junior Member Joined: Jul 2006 Posts: 3 | The truck has a 235 motor in it now,I would like to know if the i can put a 302 or 350 motor in it are the motormounts the same? if not how much truble is it to change? Going to change the trany,reared to.Also would like to upgrade the brakes,what year of truck would be the the best 70s..80s..90s? for changing all this?
thanks Carl | | |
#64837 08/26/2006 2:01 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Carl, If you do indeed have a 235 in your truck some one has put a 1962 or earlier engine in it. More than likely what you have is a 230/250. The bellhousing bolt pattern is the same for the 230/250s and the Chevy V8s. If your idea is to buy a complete donor truck for the upgrades then I would suggest a 1986 or earlier. The engine from the donor truck will just about a bolt in. There will be several ways to do the brakes. The biggiest problem will be the rear axle. You will have to cut and weld spring perches and shock mounts. You will also have to watch your wheel offsets. Sorry there is not a lot of deail here, you didn't ask for details.  If you search the archives you should find more details. Larry
I don't own a vehicle that isn't old enough to drink. | | |
#64838 08/27/2006 12:52 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you have a 302 some of the Camaro guys would give you enough for it to buy a really nice 350.
Evan
#64839 08/29/2006 6:02 AM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 |
1967 Chevy truck "The Hurricane"
WARNING: This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
#64840 08/29/2006 6:21 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | 302 equals 5 liters which the engine size limit for Trans-Am race series in the early 70s. GM, Ford, Chrysler, AMC all had 302s for the series. Todays history lesson, from an old fart. :p
Larry
