| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | I took in my 228 / 6 to a shop for a value job . They originally quoted $250, no problem. After inspection theY SAY new values and guides all around are needed no big suprise < cost of this items are around 250 DOLLARS , forget pennies and rounding . The real question is that the jumped the price to $810. I think I am being ripped, comments please. I went in for a value job not a rip of , Am I wrong, its not a engine rebuild. | | | | | Joined: May 2007 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 41 | Hey doug one,
I rebuilt one of my 228's a year ago. The head was completely rebuilt with new valves, guides, springs, and hardened seats and surfaced. It wasn't cheap, no where near $810. I paid $12 a piece for valves($144), $5 per spring($60), and I can't remember on the guides or seats, but the total with labor and machining was $420, with a hot tank, magnaflux, and pressure test. I think that you are definitely getting ripped off at $810. Now you say the parts quote was $250, that sounds OK, and 250 for the valve job with hot tank, mangaflux and pressure test, might be a bit more, but I don't see how they get $810.
54Monster | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, bout twice as much as a complete head rework should cost. I had two of them done at two different shops a couple ofyears ago and both ran around $450. Hot tanked, magnafluxed, pressure tested, new valves, guides, hard seats, springs checked and shimmed, resurfaced. I'd tell them to stuff it and find another shop.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
