Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy), 57 guests, and 2 robots.
Topics128,008
Posts1,055,285
Members48,418
#647977 05/20/2010 2:57 AM
I've noticed that when i go for a drive at night and i have the highbeams on,after about five minutes they start to go off and on.If i put the low beams on,no problems.Your thoughts gentlemen or ladies.The truck is a 57'1/2 ton.
Roy
One ear dicky #647980 05/20/2010 3:02 AM
means they're drawing too much current or else the overloads in your light switch are weak if it's an old original .... those are the contact point sets on each side of the switch
squeeze #648034 05/20/2010 5:56 AM
possibility of the Hi beam selector switch sticking causing both low and high beams to be on causing a high current.....
GMC: Get More Cash...
1958 GMC
My Webshots photos
1958GMCnut #648071 05/20/2010 1:20 PM
Riding in the Passing Lane
If you have halogen bulbs they draw more curent then the system was designed for. I would put a relay in the high beam circuit. It even helps to put one in the low beam also as you get more light.
1972 Chevy c10 Cheyenne Super
I agree with wrenchbender, when I replaced my original light switch with one from a vendor the lights would go out after a couple minutes then come back on. Drove me nuts trying to find grounds and checking every connection.I put a relay in and have had no problem since, very easy to do and not expensive as relay can be had from any flaps.
Tommy
59 apache 1/2t
261 short stepside
Tommy #648095 05/20/2010 2:30 PM
You shouldn't be driving around all the time with you bright lights on anyways. Don't you have street lights in Toronto?
LOL
Dennis
oldbluetruck #648133 05/20/2010 5:52 PM
Gotta keep the high beams on to keep track of them Mosses and them Bears Oh My,
LOL
Pete
squeeze #648271 05/21/2010 3:11 AM
Squeeze,i have a painless wire kit,nothing original left,but,i will still check the switch.
Hey 58,my dimmer switch is on the floor so i will be gettin down and checking that out.
wrenchbender,i don't have halogens,maybe one day.
Tommy, thanks for the input.Will talk to my bud about a relay.
Last but not least Pete,the mooses and bears are about 2 hours north of me,so no worries.
Thanks to you all for the input,i will let you know how i make out.
Roy
Old blue,yes we do have street lights,but they are there so people can see ME,thank you very much.
