| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64819 08/25/2006 5:50 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | I keep my 51' 3100, parked in the garage when not in use. I noticed a strong odor of gas one day, upon inspection, I found gas just running out of the filler neck, out from under the gas cap! The tank was not over full. My thought was that perhaps the vent in the cap was clogged, so now I am on my third cap(last one was new from Jim Carters), same result! This has ben going on now for about 3 weeks! Gas just rises up the filler neck, and literally pours out the top. In almost 50 years, this is one I have never run across before. Has anyone had this happen? if so, any suggestions as to a fix? I will have to re-paint part of the cab now, due to the gas ruining the paint. Thanks! | | |
#64820 08/25/2006 6:02 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | With gas at 3.00 a gallon, you should sell the excess, might pay for the 'bolt. | | |
#64821 08/25/2006 6:42 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Had you just filled the tank when you parked it? Have you driven it since it started overflowing? | | |
#64822 08/25/2006 11:56 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | My '58 will do that in the summer heat if I fill it too full. May try to leave more expansion room in the tank. I quit filling mine to the very top and it helped. | | |
#64823 08/25/2006 6:06 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I believe my truck has a tube that comes out of the top of the float/sensor fitting on the gas tank and runs under the truck. I've never seen it drip but I assume its more for allowing air pressure to escape. Like Roy says, if the tank is pretty full and then heats up, it may be the cause of the overflow. | | |
#64824 08/26/2006 2:19 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mine did that too, especially on really hot days. In addition to leaving space in the tank, stay away from parking spaces that will tilt the tank toward the neck. Had that experience earlier this summer.
Bill Burmeister | | |
#64825 08/26/2006 4:48 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | Thanks Everyone! Yes I had Filled it before I parked it, though I did not think too much about it, since I didn't squeeze it in. It did appear worse on hotter days, 95 - 100 degree's. Drove her all this weekend, and no gas out. I will start keeping the tank a little less full, and watch parking on the hills. chevman32, I actually tried to a figure a way to capture the gas! :p | | |
