7 members (GMCJammer51, walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 85 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#6480 06/27/2004 11:46 AM
Junior Member
Junior Member
Good morning fellow Bolters. I am looking for any info on the modifications to the steering column for my '65 4x4 Burb when I install a mid 80's front axle w/ disc brakes this week. Any info is appreciated. Have a good 4th and Bless our troops.
Swampratt,, what steering box do you have now? power or manual?
You can make nearly any steering column fit with a little fab work cool
Junior Member
Junior Member
I currently have the original manual box but the old beast really needs to go to power steering. I will start locating all of the brackets this week for the power steering, so any info for this application would help. Thanks!
Be sure to get the reinforcement plate that strengthens the frame where the steering box mounts.
Are you going with a lift? If so, How high?
May want to think of going with a 2wheel drive steering box so you can go with a cross-over steering (tie-rod steers from the right side and helps a lot to eliminate bump-steer when 4-wheelin` grin .
Junior Member
Junior Member
I appreciate the help. The old Burb has been in the family since new but has never been off-road, but your suggestion with the 2 wheel drive box will be used. The donor truck for the front end has a 4in. lift so I will probably go ahead and put the old Burb up in the air. Thanks again and have a good 4th.
