6 members (Gdads51, Otto Skorzeny, Opelika Tom, crenwelge, 78buckshot, 1 invisible), 103 guests, and 2 robots.
Topics128,062
Posts1,055,851
Members48,428
#647890 05/19/2010 10:30 PM
So my freshly rebuilt 235 was running smooth on first start. When I went to start it again, the carb backfired and gas started coming out of the side of the carb where the throttle linkage is. I have rebuilt the carb AGAIN, but I don't want the same thing to happen. My first start was successful with the pointer on the line between the U and C on the flywheel and the rotor on plug 1. Is this too far advanced? Not enough? Should it be dead on the steel ball and plug one? The engine is not 180 degrees out either. Please help...
1946 2 Ton Flatbed
gatsby46 #647934 05/20/2010 1:06 AM
Dead on steel ball and plug # 1 or even alittle retarded.
Pete
Pete52 #648004 05/20/2010 3:35 AM
I'll give it a shot in the morning... Thanks Pete.
1946 2 Ton Flatbed
