5 members (JoergK., cmayna, Otto Skorzeny, TexasJim50, Opelika Tom), 92 guests, and 6 robots.
Topics128,185
Posts1,057,205
Members48,465
Apprentice
Apprentice
Have a 50 GMC 100, finally made the connection between the late model rear end emergency brake cables with the rest of the system. Now it's onto the stock e-brake pedal and release mechanism. The problem is it just wants to "release" all the time. When the pedal is applied it is supposed to be set using the friction of the e-brake pedal rod and a metal plate that it runs through. You "AD" truck owners know what I'm talking about. So I was thinking I could probably bend the end of the metal "brake release" plate to create a sharper angle and hopefully more friction. Was wondering what others have done. Nice to have a working e-brake with a manual trans truck.
Alex
PiLe dRiVeR 13
Yes, friction in that hole is supposed to hold it. I wonder if the metal plate can be flipped over.
Just try and sharpen the edge of the inside of the hole that the foot brake rod goes thru most of the time the edge is rounded off and does not bite the rod and make sure the spring pushes up on the metal plate so it will bite the rod.
Pete
Pete
Good advice Pete, just done the same thing,worked like a charm!
10 minutes with a rat-tail file,and I also gave the spring a little stretch too, just to increase the pressure.
More pix on Flickr.
