6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#647836 05/19/2010 7:26 PM
I was checking all my brakes and front bearings out before summer started and found my rear brakes to be oiled and gummy, again. First time I thought it was my wheel cylinders, so I replaced them. Well I definatly can smell the gear oil now. I already have seals and bearings so I thought I would just go ahead and replace those. I wanted to know how one may test the axle vent/valve to make sure it is working? This isn't the first time this axle has done this. My brother redid the seals and stuff once before already. I just want to do this right and make sure I won't have to do it again, for a long time at least. Any advice or suggestions, please bring them! Thanks for the help!
58' 3200 235 3-speed/OD
Look closely at the seal area on the axle, they are commonly pitted. There is a speedi-sleeve available to fix this problem.
My Blog
Riding in the Passing Lane
The vent is on top of the axle housing. It has a little cover over it. If you can turn the cover it is OK.
1972 Chevy c10 Cheyenne Super
I had a similar situation on my '51 AD where I had begun to get gear oil on one rear brake. After driving it and having one wheel drag, I pulled the drum and saw oil all over. Curious as to whether I had lost a lot of oil I opened the fill plug on the differential and to my surprise, got a puff of air (I had just returned from a drive and the diff was warm). Of course, that caused me to examine the axle vent, where I found it was completely sealed by crude and corrosion. I cleaned it up with a little gun solvent and then cleaned up my shoes and drums with brake solvent and have never had a problem since. I didn't have to replace seals or shoes.
The vent is just a 1/8 pipe thread on my AD. Check it out, maybe you can get lucky, too, and your seals might be OK.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
