| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Looking good. I did a 51 GMC over 30 years ago that now has around 300,000 miles on it. It wore out the 472, which was rebuilt once, and the 500 in it now has close to 100k on it. It's stock with the a/c compressor still mounted into the front of the intake manifold. That big booster will give you super brakes but one suggestion I have is to fab a really strong crossmember to tie the front of the frame rails together. Without one the power steering will flex the front of the left rail due to the weight of the engine and probably wider tires. The torque is amazing.
Evan
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I've got a 59 Burb waiting its turn for shop space, with a 500 Caddy, Turbo 400 trans, and a Dana type 60 3/4 ton rear end out of a late-70's GMC pickup headed into it. I've also got an early 80's 3/4 ton IFS scheduled to be narrowed and installed to relace the 1/2 ton straight axle during the buildup. Can you say "heavy hauler" for trailers. etc? Jerry
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Looking good!
I'm putting a 500 Cadillac in a '54 GMC 1-ton. I'm using a GM 14-bolt rear and the IFS from a 70's 3/4-ton.
Cadillac motors seem like fun!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looking good!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
