4 members (RaNfLaS, Tyler Watts, DadsFirstPickup, 1 invisible), 88 guests, and 1 robot.
Topics128,047
Posts1,055,662
#647732 05/19/2010 4:46 AM
Apprentice
Apprentice
I've been working on my project and have made some progress. I'm going to try and put a link to some pictures so bare with me.
The truck is a 54. The engine is a Caddy 500. The rust is extensive.
http://s987.photobucket.com/albums/ae353/brihill18/54%20chevy%20pickup/
Brian Hill
brihill18 #647741 05/19/2010 5:47 AM
Looking good. I did a 51 GMC over 30 years ago that now has around 300,000 miles on it. It wore out the 472, which was rebuilt once, and the 500 in it now has close to 100k on it. It's stock with the a/c compressor still mounted into the front of the intake manifold. That big booster will give you super brakes but one suggestion I have is to fab a really strong crossmember to tie the front of the frame rails together. Without one the power steering will flex the front of the left rail due to the weight of the engine and probably wider tires. The torque is amazing.
Evan
coilover #647857 05/19/2010 8:56 PM
I've got a 59 Burb waiting its turn for shop space, with a 500 Caddy, Turbo 400 trans, and a Dana type 60 3/4 ton rear end out of a late-70's GMC pickup headed into it. I've also got an early 80's 3/4 ton IFS scheduled to be narrowed and installed to relace the 1/2 ton straight axle during the buildup. Can you say "heavy hauler" for trailers. etc?
Looking good!
I'm putting a 500 Cadillac in a '54 GMC 1-ton. I'm using a GM 14-bolt rear and the IFS from a 70's 3/4-ton.
Cadillac motors seem like fun!
OldSub #648032 05/20/2010 5:42 AM
Looking good! thumbs_up
Robert C.
I'm a Genius in the making.
1950 3600
