5 members (Gray_Ghost, 49choptop, Guitplayer, pauld, Forty9), 101 guests, and 4 robots.
Topics128,201
Posts1,057,281
Members48,467
#647685 05/19/2010 1:30 AM
I am in need of the max and min turning diameter for the front drums. I have the manual but it only states the drum diameter.I want to check my drums to see if they have enough material to turn them.
I have a 1964 C20 2WD.
According to Napa Auto the front brake drum for a 1964 C20 uses 11 5/32” x 2 ¾” brakes. Inside diameter is 283.2 mm which equals 11.149606 inches. Maximum discard diameter is 284.73 mm or 11.2098425 inches.
http://www.napaonline.com/Search/De...99645&An=599001+101964+50014+2014028
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
I also found out that the drums shouls be marked with these numbers.
I will check this when I remove the drums for possible turning.
