1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64740 08/23/2006 7:36 PM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Would there be any problems with putting a radiator (PN#3128514) from a 2-ton in a 3/4 or 1 ton AD. Of the several I have, it's the best bet to repair. The only difference I can see is, it appears thicker. Appreciate any feedback. | | |
#64741 08/23/2006 9:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it fit,s go for it. Check the position & size of the hose connections. If they are not right the radiator shop can modify them. Check all dementions & mounting holes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#64742 08/24/2006 2:17 AM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Thanks WB, it has the same dims & the extra 1/2" is on the grille side. The distance between rad & fan blade is the same as a 1/2 ton. | | |
