5 members (Gdads51, Wooley, Otto Skorzeny, TUTS 59, cmayna), 153 guests, and 0 robots.
Topics128,113
Posts1,056,612
Members48,450
#646953 05/16/2010 3:11 PM
can a 235 oil pan be put on a 261? I have to replace my pan (rod went through side)and i have a 235 pan, it will bolt up. The 261 appears to be a deeper sump and the oil tray (lack of better term)is in different location(vertical) and 235 is horizontal. Thanks for all the help people!!
3B Offline
Hy tobin1959, welcome, yes the two oil pans should bolt to the same block, be it a 235 or 261. That being said the two pans you have may not be interchangeable for your application, chassis constraints, oil pump pickup locations, oil capacities, may be different. If you want to change the pan to the good one you have, you must make sure it will work in your chassis, and the oil pump pickup will end up in the new pans sump, and allow the pan to bolt up to the block, good luck, hope that helps.
thanks for the info. i will have to do some measuring to see about chassis clearance and depth of sump. Hope this works out....not sure where to find another 261 pan??
How bad is the damage to the original pan?
Maybe you could repair it.
It's just stamped sheet metal,
so you should be able to weld in a patch panel
as long as the gasket rail isn't damaged.
regards,
Leon
It is not that 261 pans are different, but there were three different oil pick-ups used through the years, and each used a pan to match the pick-up.
My Blog
anyone know where to find a 261 pan?!!!! I've searched Ebay, no luck. I'll keep on trying.
Place a Want Ad in the Swap Meet?
