| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Were the frames for GMC and Chevys different. For example the front cross member where the motor mount is. I looked at a 56 GMC which belong to Mr. Wingfield here in Richmond and his front cross member was completely different from mine. I've owned a 55 56 and a 57, all Chevys, in my past and they all had the same cross member as is on my 58 GMC. So was there a different frame or is mine a Chevy with a GMC cab. Thanks in advance Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Larry,
Yes, from 47-55 (at least) GMC and Chevy frames were different. The major difference had to do with the front cross-member - GMC engines (six cylinders) were all longer than the Chevrolet engines.
For at least 47-53, the GMC and Chevrolet cabs were the same (fenders, grills, gauges, and hoods were different).
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | biggest difference is the 47-55 frames tapered in twords the front 55-59 were strait looking more like a ladder
1937 1/2 ton
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I believe the original engine for this truck was a 270 which from what I've been reading uses a block built by Atlas in detroit which was the same as a 235 but with a little taller deck height and larger bore and stroke. The 56 I looked at had the 270 in it and it looked like my 235 only with a different valve cover, 2 bolts holding it down as opposed to the 4 bolts on the side of the 235. All this may be a blessing as it may be easier to get 235 parts than the 270. I have a Chevy grille in it and I think I have the 58 GMC grille only it has a cross piece missing off it. If I can find or make the cross piece I may change it for the GMC look since I have the little 100 emblem that mounts on top of it. Might be nice to have that GMC look.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are very few 235 parts that can be used on a 270. But that discussion should be in Engine and Driveline. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 |
