3 members (Otto Skorzeny, 3B, 1 invisible),
38
7
Mod | | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I am looking for recommendations for a decent timing light to replace my 30 year old Craftsman inductive unit. A professional mechanic suggested that it might be time to replace it since his Snap On unit and mine disagreed by 8 degrees when measuring initial advance at idle and by 14 degrees at full advance. My price range is around $100.00. Thank you.
Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | what engine? how is it running with that amount of 'disagreement'? if I had 2 tools disagreeing that much and the engine ran decently, I'd be wanting a 3rd opinion  Bill | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | The engine in question is the 258 in my CJ, but I used the timing light for my 57 Chevy 1/2 ton with a 235 as well, so I hope I'm sort of on topic. The reason the subject came up is that the Jeep wasn't running very well at all...no wonder, given how far the timing was out. So the Snap On light was accurate and my old light was not. It had been dropped and otherwise abused over the years by someone who will remain anonymous.
Bill,
I like the quotes in your sig...#2 is too true... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hahaha, you must buy the same kinda trucks I do! and the topic being tools, can't really be off topic, I just was curious about an engine 8-14* out that would run!
well, if the old one looks to have been abused, back to the original question - I'd just run down to my local favorite tool place and buy what I could afford, I don't see any need for top dollar with things like that
Bill | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Yeah. I am just looking for something that will be as accurate as my old one was when I got it back in 1978. It held up pretty well for 30 years or so, just like my marriage! | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Larry,
If your local O'Reilly's Auto Parts will loan you one out of their loaner bin, take and check it against your trusty Craftsman and make sure it is truely off. Also, might be the way to go unless you use one a great deal. Just my .02.
Hank
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thanks...great idea. I do use a timing light fairly often doing tune ups on the family rigs and those of friends who claim to be mechanically deficient. Of course I leave my wife's Subaru alone, but anything with carbs and points I can deal with. I've even managed to swap in a TBI and HEI into the old CJ and it runs!
Larry | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | So, anyway...any ideas on particular brand names of timing lights? Thanks again.
Larry | | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | I quit using timing lights years ago. mostly due to the rubber on the harmonic balancer slipping. My dad taught me how to use a vacuum gauge to set timing. Hook it up to manifold vacuum and set the carb idle mixture to around 18 inches,turn down the idle to 500rpm or so,turn the dist until you get the highest reading and back off 1or2 inches of vacuum. This has worked on everything from a '47 ford 8n to my CJ7. | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thanks. I have done that before, but I sort of got out of practice. I'll try it.
Larry | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have an old Sun 6v timing light I never use if you're interested.
| | | | | Joined: Sep 2009 Posts: 3 New Guy | | New Guy Joined: Sep 2009 Posts: 3 | Quick question, does either timing light that you are using have an adjustment knob/switch? I would disregard the one with the adjustment if it had it.
Buick Truck Guy
1915 Buick C-4 Express Delivery Truck 1918 Buick E-4 Express Light Delivery Truck
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | The pro's Snap On unit had one. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hey Tiny. When I get the 48 back together it will be 6 volts. I may ask you if I can borrow your timing light. Unless Dune (or somebody) can help me use my vacuum gauge to tune the 216.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Looks like the ownership of my old Sun unit is going to change. I'm currently in heated negotiations over price.
| | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I don't want to mess up Tinys deal, but the timing light does not have to be connected to the same battery that the truck is running. You can connect to another 12 v battery for the 6v system, kinda a timing light jump-start if you will. | | |
