| | | Forums66 Topics128,184 Posts1,057,270 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 25 | Hello... does anyone know where I can find a 1934 Chevrolet Master Sedan replacement fuel tank (preferably a polypropylene)? Also, will a 1935 Master fit a 1934 Master fuel tank? | | | | | Joined: Oct 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 25 | Found the problem(s)... here is the list of things I found that created the no-start problem:
1. Spark plug electrodes in the #3 cylinder. Someone just put another spark plug in rather than finding out why the electrodes were being broken off in the #3 cylinder 2. Carburetor needed replaced. Too many leaks. 3. Fuel lines plugged... varnish! 4. Fuel tank plugged... varnish! 5. And finally... conversion from 6V to 12V... much more power to the starter. | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | I think you posted the starting problem in the wrong posting? maybe a moderator can put it in the correct spot? Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
